Old 08-17-2011, 01:49 AM   #1
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
Red face Street/Strip Engine help
Hello guys! Hey I'm wanting to build a "milder" engine for the Camaro. 1st I'm building it with what parts I already have...goal is to run between 13.00 & 13.20. What I have .040 over 350 block , 3.25 crank, Manley rods, Performer intake, Deano Q-Jet , 9" converter (foot brakes 2700) 4.11 gears . (BTW this is a 67 Camaro) My question is what heads to use???? I have 520, 416, 624, 441, & a set off my dad's 86 Chevy truck that had a 305 but can't find the #'s in the blueprints. The 441's are 1.94 int 1.60ext. the others are bare/OEM stock. I'm think of putting 1.94 valves in the truck heads leave the 1.50 exh (hardened exh seats) gasket match them & go. What would you guys do??? Also flat top or .150 dome pistons??
Old 08-17-2011, 07:23 AM   #2
Robert Simpson
Liked 20 Times in 12 Posts
Talking Re: Street/Strip Engine help
Greg, I would like to buy the 441's from you if you don't use them. With that being said the 441's would work just fine but like you said for any long term street car you need to have hardened seats installed. I have used the 416's with good success on small motors 305's and 307's. But they come with the 1.84's, which I believe you can up to 1.94's. Don't use the 520's the runners are two small for this application. I know they were used on 250hp 327's but you have a choice for a better head. But, from my experience if you can swing it get a set of later model vortec heads. I can't remember the p# but out of the box with a low lift street cam they really do work! I do not see you combo having any problem running the times desired. Good luck. By the way your converter, that is a 10" correct? Let me know about the heads?
Robert Simpson is offline   Reply With Quote
Old 08-17-2011, 08:06 AM   #3
Billy Nees
Liked 7,682 Times in 1,730 Posts
Default Re: Street/Strip Engine help
Use 416s with 1.84 valve and flat piston.
Billy Nees 1188 STK, SS
