Old 08-16-2011, 05:20 PM   #1
John Beasaw III
Liked 2 Times in 2 Posts
Default Holley carb problem
Just rebuilt my holley 750 vacuum carb. The car will only fire with the throttle held part way open. Then will idle for a few seconds and shuts off. Also If i start it and hold it at 1500 rpm, then give it gas it shuts off.
Thought vacuum leak but cant find one.
Any help would be appreciated. Running out of ideas.
Thanks
John Beasaw III is offline   Reply With Quote
Old 08-17-2011, 08:11 PM   #2
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
Default Re: Holley carb problem
John, almost sounds like you installed the wrong base plate to body gasket. There are several different ones and are all close. If you used the wrong gasket, it will cover and block the wrong passages and wont allow the carb to idle. Also (as im sure you know) dont run the mixture screws in real hard in the metering block it will dimple the screw and cause funky idle issues. My bet tho is the wrong body to base gasket.
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 08-18-2011, 09:10 AM   #3
John Beasaw III
Thanks Duane... I'll check that tonight.
Old 08-18-2011, 09:38 AM   #4
Duane Eiskant II
No problem John, please let me know what you find out.
Duane Eiskant
Old 08-18-2011, 05:10 PM   #5
cad
cad's Avatar
Liked 93 Times in 52 Posts
That is exactly what I experienced a while back....make sure the gasket matches the base and center section with the 4 oval slots.
If they are covered, the car will start and die immediately, over and over and over....like it is running out of gas instantaneously.
