Old 08-08-2011, 11:38 AM   #1
428tom
Default Best Front Coil spring for fox body Mustang?
Looking for the best front coil spring to run in a fox body mustang?
428tom is offline   Reply With Quote
Old 08-08-2011, 10:49 PM   #2
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Default Re: Best Front Coil spring for fox body Mustang?
probably moroso trick springs, think there is 3 different part numbers, depending on front end weight
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 08-08-2011, 11:51 PM   #3
Liked 5,077 Times in 1,935 Posts
The factory 4 cyl. springs work pretty good. Can't beat the price in U-Pull-It
Old 08-09-2011, 03:05 AM   #4
HawkBrosMav
Liked 302 Times in 73 Posts
What is the benifit of running the 4 cylinder spring with the 302 in the car? I feel like with no sway bars on our 89' and the V8 spring in it the car already has too much nose movement.... especially when i grab the brakes a lil too hard at the stripe... I would hate to see how far the nose would drop with a lower spring rate..
Can you elaborate Mark?
Old 08-09-2011, 06:02 AM   #5
Earle Holt
Liked 4 Times in 1 Post
Mark is right, the 4-cylinder springs will work. They really drop the front-end down quite a bit with the 302, but don't work as well as aftermarket springs in that the nose will come up quickly off the line, then drop back down like a dead fish before you get past the tree. They really just don't have enough pressure to be nice and "springy" loose like you want unless you have a 4-cylinder car like Mark's but they are an option if you're on a tight budget.
For a good set of springs that will come up quickly then settle down to ride height gradually like they should with 90/10 struts, call Laurel Mtn Mustang and get their front drag springs. The springs are powder coated (yellow). Cut 3/4 of a coil off each one and you'll be good-to-go.
Been there done that.
Earle Holt 1055 Stock
Earle Holt is offline   Reply With Quote
