Old 07-17-2011, 09:12 PM   #1
fastmachone
Question IHRA Crate Motor Stock
What is the camshaft rule for IHRA Crate motor Stock?
fastmachone is offline   Reply With Quote
Old 07-17-2011, 09:23 PM   #2
Kegracing
Default Re: IHRA Crate Motor Stock
About the same as all stock... you can change duration, but not exceed the spec on lift. Valve spring rules are about the same as all other also, cant change size from stock, but can increase pressure.
IHRA let's you run roller rocker arms on all motors, traditional and crate.
Hope this helps.
Ken
Kegracing is offline   Reply With Quote
Old 07-17-2011, 09:30 PM   #3
fastmachone
Cool Re: IHRA Crate Motor Stock
Thanks Ken, that helps out a lot.
