Old 07-11-2011, 10:13 AM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Leaving crooked
The car jumps to the right at the hit. Like it's unloading the RR. It acted the same on both of the runs below, it's just hard to see from the side view. I haven't checked bar pre load yet.
Shocks are at 0-0
Tire pressure is even at 10lbs in 32x14's
Foot brake, leaving at 3
Ladder bar with sliders and mono leaf.
I appreciate any helpful opinions
Ron Gusack is offline   Reply With Quote
Old 07-11-2011, 10:21 AM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,903 Times in 571 Posts
Default Re: Leaving crooked
I would check the front holes on the ladder bar mounts real close. They are probably oblonged. Two different lanes same issue. If you have to have preload on your ladder bars there is something wrong with the car. Make sure there is no wear on any of the brackets or bolts. Then check to see if the rear is square in the car. My car was doing the same thing. worn brackets.
Mike Pearson 2485 SS
Old 07-11-2011, 10:19 PM   #3
Ron Gusack
Ron Gusack's Avatar
Thanks Mike, I'm pretty sure the rear is square, but I haven't looked at the brackets and bolts in a long time.
