07-06-2011, 04:54 PM | #1 |
Liked 852 Times in 299 Posts
Best available cast/aluminum GM small block intake
I was ask this question at work today...... This young guy is building a pulling truck (1972) and it has to be "stock appearing" to meet class requirements. He is going to put a 434 short block in it as they do not pump them . We will set him up with a 800 cfm quadrajet, but I know nothing about stock intakes. Any suggestions?
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 07-06-2011 at 04:56 PM. |
07-06-2011, 05:04 PM | #2 |
Liked 1,092 Times in 286 Posts
Re: Best available cast/aluminum GM small block intake
Probably the old 70 LT-1 intake. A few years ago, Chevy also had a BowTie aluminum dual plane intake, and a marine cast iron version that accepted a Q-Jet with no adapter, it was released for circle track classes that required a cast iron intake that accepted a Q-Jet without an adapter.
Alan Roehrich 212A G/S |
07-06-2011, 05:08 PM | #3 |
Liked 224 Times in 103 Posts
Alan,
Just a note, 70 LT-1 was a holley and your going to pay $$ when you find one. |
07-06-2011, 05:15 PM | #4 |
Liked 65 Times in 36 Posts
I have a cast iron marine with the chevy casting numbers. Looks like a performer RPM. $200 Yes it's fast!
72 cutlass |
07-06-2011, 06:00 PM | #5 |
I'm well aware of all of that. The OP was fairly vague, they just said stock aluminum intake, nothing about cost or the need for an adapter.
07-06-2011, 06:28 PM | #6 | |
Daran, If this is the cast one Alan is talking about, send me your phone # and Ill have him call you. I warned him that you stocker guys have good stuff, but its hard to get, and he might have to pay more than he thinks for it. I know he is going to ask, so how much " better" is the Aluminum Lt-1 style verses the cast ones. And what do they go for ? Jeff
Jeff Niceswanger 3740 SS |
07-06-2011, 06:45 PM | #7 |
Jeff,
We never tried the iron intake on any "big" engines, but it ran really well on the 350-400 flat tappet iron head engines, well enough that most of the circle tracks outlawed it. That intake was very similar to the old Chevy dual plane high rise intakes, but it was a much later design. As far as comparing the intakes, I'd guess you'll be hard pressed to find any serious data, as anyone using a stock intake had to use it, and anyone with a choice usually went straight to the speed shop and bought an Edelbrock or a Weiand, and sold the stock intake. If the kid wants to really pony up, he can always grab a good casting and send it to Brezenski, they specialize in the cheated up stock appearing stuff. As far as the market value of an LT-1 intake, just grab the casting number out of the blueprint guide and plug it into your favorite search engine. SOME of the stock stuff has dropped recently, by a considerable amount.
07-06-2011, 07:33 PM | #8 |
Thanks Alan, I'll see what I can do to keep the kid broke, We all know we're good at it.......
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 07-06-2011 at 07:35 PM. |
07-06-2011, 07:35 PM | #9 |
813 783 4495 I back to backed it against a Torker ---- No difference. Let me know.
72 cutlass |
07-07-2011, 02:02 AM | #10 |
Some of the best cast GM intakes you can find are the 10051103 and the 10051102 .As far as actually using one would depend on if stock appearing meant that it has to look stock or if it is just required to be a part that is actually made by GM and is available through the GMPP catalog which both of these are.
