Old 06-24-2011, 09:36 PM   #1
Lonnie Cox
Default Intake Center Line
My question is if your intake center line is set at 108 and should be 102 would you have less clearance piston to valve? I think we found our problem being down on power. I now am worried about clearance. Should I be?
Thanks to all of you for helping.
Lonnie Cox is offline   Reply With Quote
Old 06-24-2011, 09:44 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Intake Center Line
Your intake valve would have more clearance at 108 than 102.
Ed Wright 4156 SS/JA
Old 06-24-2011, 09:54 PM   #3
Bob Bender
Bob Bender's Avatar
Liked 462 Times in 92 Posts
x2
Bob Bender 144 O/SA
Old 06-24-2011, 10:54 PM   #4
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
http://www.compcams.com/Technical/FAQ/LSAproperties.asp
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 06-24-2011, 11:56 PM   #5
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
And the exhaust clearance will be less.
Ron Gusack is offline   Reply With Quote
Old 06-25-2011, 12:55 AM   #6
Liked 1,953 Times in 439 Posts
If you are now moving your intake center line to 102 from 108, to correct your problem, you will decrease intake valve to piston clearance.
Old 06-25-2011, 08:50 AM   #7
Ed Wright
Ed Wright's Avatar
Of course.
Old 06-25-2011, 11:00 PM   #8
Greg Reimer 7376
Liked 727 Times in 221 Posts
Cool Re: Intake Center Line
Advancing the cam decreases the intake piston to valve clearance and increases the exhaust piston to valve clearance.Retarding the cam that much increases the intake piston to valve clearance,and decreases the exhaust valve piston to valve clearance. Also, advancing the cam increases torque and reduces peak horsepower.Retarding the cam decreases torque and increases peak horsepower.Wouldn't it be great to be able to use a variable cam timing device that allows you to leave the line in at 98,and cross the finish line in at 108?Also, the weight of your car can affect where the engine wants the cam. My K/SA 68 Chevelle hardtop might just want it somewhere else than my O/SA 68 Chevelle wagon.Those two cars weigh 490 pounds different.
Old 06-26-2011, 06:59 AM   #9
Jim B
I don't know your application but you may want to invest a couple of minutes and leak the engine before a trip back to the track. In a minimum valve clearance built engine running the cam 6ยบ retarded from the checking centerline will reduce exhaust piston to valve clearance beyond the safety margin and the piston may wind up closing the valve. It may not apply to you but it's just a thought.
Jim B is offline   Reply With Quote
Old 06-26-2011, 11:52 AM   #10
Adger Smith
Liked 880 Times in 311 Posts
Lonnie,
You got some very good answers in this thread.
I would never consider moving the cam around, very much, to get PTV clearance. Depending on the lobe profile & rocker ratio you only get between .005 to .008 clearance (change) per degree of cam movement. Some more, some less....
Another issue with retarding the cam is the ex valve will open at a later point in the cycle. A late opening of the ex valve can be a problem when trying to produce power at high rpm. At high RPM it can cause lost power by what is called pumping losses. At High RPM the late opening causes the Ex to loose some of the blow down affect and the piston has to pump the spent ex gasses out. In real bad cases there can be ex gasses trying to go back into the intake runner when the intake valve opens. That really kills power.
Adger Smith (Former SS)
