Old 06-18-2011, 09:06 AM   #1
Knocky
Default 8V battery upgrade on tractor, 14V on race car?
I can't find much discussion on the 14 volt batteries (XS makes a couple) Looks like most racers upgrade to the 16v systems from 12v.
Do ya'll think the 14 volt is a good upgrade/compromise ?
Alternator is an East Coast mini. Engine mgt syst is Mopar (AEM) computer and they recommend up to 14.8 volts.
We were putting a battery on our 1938 Allis Chambers 6v tractor, I found out it is (was) common for farmers to use an extra cell 8v upgrade(I had never heard of) and that's what we used-works great!
Thanks, MWNorris
Knocky is offline   Reply With Quote
Old 06-18-2011, 08:50 PM   #2
Dragsinger
Liked 99 Times in 60 Posts
Default Re: 8V battery upgrade on tractor, 14V on race car?
I have no experience with 14 volts but it seems reasonable that it would be a good upgrade. My question is about charging a 14 volt battery; How is that accomplished?
Larry Woodfin 471W
Old 06-18-2011, 10:14 PM   #3
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Dont most 100amp 12 volt alts put out 14.2 volts
Bob Pagano A/SA
Old 06-18-2011, 11:02 PM   #4
Knocky
Yes Bob, that is my thinking. The alt should keep it up at the track & there is a 14V charger available...On the other hand it does not have as many cranking amps as a heavy duty wet cell 12v...
Mark
Old 06-18-2011, 11:21 PM   #5
Dragsinger
here is my concern; to charge a 12 volt battery requires about 14.5 volts. To charge a 16 volt battery requires about 18.5 volts. So, it is reasonable to estimate it will take about 16.5 volts to charge a 14 volt battery. Thus a dedicated alternator and charger will be required.
Larry Woodfin 471W
Old 06-19-2011, 12:08 AM   #6
Knocky
Yes, I see Larry, for full charging of the 14v. The 14v is the gell cell type and will drop off quick if gets low from what i understand. I'm leaning toward starting off with a proven heavy duty , high amp 12v battery w/ the mini alternator and keep the battery fully charged before heading to track!
