Old 06-12-2011, 06:25 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default low gear X rear gear, an updated recommendation
Many years ago ATI offered a suggested starting line ratio based on engine stroke and car weight. Much has changed since those days. Is there an updated/suggested ratio guide line formula?
Larry Woodfin 471W
Old 06-12-2011, 09:37 PM   #2
Wade_Owens
Wade_Owens's Avatar
Liked 3 Times in 1 Post
Default Re: low gear X rear gear, an updated recommendation
Larry, I would be very interested in seeing the "old" recommendations if there arent any new ones......
Wade O
Old 06-12-2011, 09:44 PM   #3
Dragsinger
Wade, I will find them. The chart has been posted on several message boards.
Larry Woodfin 471W
Old 06-12-2011, 09:46 PM   #4
Dragsinger
Wade, did not take long
http://drr.infopop.cc/eve/forums/a/t...12/m/441102691
Larry Woodfin 471W
Old 06-12-2011, 11:05 PM   #5
Adger Smith
Liked 880 Times in 311 Posts
Larry,
Did you notice something about that chart.... All the different strokes only have a .75 ratio spread between the bottom and top weight. I was way over the suggested start line ratio when I was running a PG in my car. I would say this is just a get started suggested number. I put a 1.76 in place of my 1.98 as an experiment to keep from hitting an index. It worked, my ET dropped .15... Made the 60's way slower. That was a 12.53 over all to a 11.14 in a 3175 lb car. I think the % drop in 1-2 shift made more difference than the start line ratio. It got in high gear too far down track and didn't let the converter work. A long, long time ago a person that was on top of things told me to pick the tire/rear gear for the desired MPH and the tranny low for the launch ratio. With today's converters I think 2 more factors should be considered. The torque converter ratio and the gear drop % go hand in hand.
Adger Smith (Former SS)
Old 06-14-2011, 02:57 PM   #6
gtaa
Liked 4 Times in 2 Posts
Hi
Is there a recomendation for 3 speeds also?
M.Lind
gtaa is offline   Reply With Quote
Old 06-15-2011, 01:16 AM   #7
Adger Smith
Low! :~)
