Old 06-02-2011, 10:54 AM   #1
Jim Kaekel
Liked 531 Times in 108 Posts
Default Electric Tongue Jacks
One regret I have when I ordered my 28' Classic Dominator trailer is that I didn't get an electric tongue jack. Does anyone have any recommendations regarding what brand to buy and where to get it?
Jim Kaekel 3836 STK
Old 06-02-2011, 12:41 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: Electric Tongue Jacks
Jim---2 brands come to mind Fulton & Reese--my daughter has a Fulton on her 27 foot boat trailer no problems in 5 years--I have had 2 Reese jacks first one motor died at about 10 years sent it into Reese to be rebuilt cost about $30 including shipping--second one has been on the trailer for about 15 years no problems---get a bolt on just remove your hand jack and its a simple bolt in uses the same holes just make sure you have a good sized cable going from the battery to the jack---also make sure ya get a jack with a built in light makes it easier when hooking up in the dark--I also made a canvas cover to keep the weather off o it too
Old 06-02-2011, 01:01 PM   #3
jmcarter
jmcarter's Avatar
Liked 3,179 Times in 972 Posts
Another thread on same subject....
http://classracer.com/classforum/sho...highlight=Jack
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 06-02-2011, 01:04 PM   #4
Philip Saran
Liked 14 Times in 11 Posts
I have a VP-3000 by Barker MFG, Battlecreek, MI on my
car trailer. Only had it a few months, but happy with it so
far. I have it wired into the 7 pin connector so it only works
with it plugged into the truck. It came from my local RV
store and was in the $230 range.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 06-03-2011, 11:03 AM   #5
John Dinkel
Liked 263 Times in 68 Posts
Thumbs up Re: Electric Tongue Jacks
Jim,
Get VP 3000, I have had one since 2003 with no problems.
John Dinkel 3295 STK
John Dinkel is offline   Reply With Quote
Old 06-07-2011, 05:50 PM   #6
trmnatr
What winch do you guys prefer? SuperWinch? Want to get one that will work when needed, I have seen some friends fight with cheaper winches. Figured some in this thread may have an idea, Thanks in advance
trmnatr is offline   Reply With Quote
Old 06-07-2011, 09:31 PM   #7
sc180b
Check out surpluscenter.com for electric tongue jack and winch....
sc180b is offline   Reply With Quote
Old 06-14-2011, 08:36 AM   #8
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Question Re: Electric Tongue Jacks
I put a SuperWinch 5000 in when I got the Volare (3300 lbs). Worked great but after about a year it started squealing like a little girl while loading the car. Unloads fine, no noise. Sounds like a clutch or something, I don't profess to know how the winch works. If I did I would try to fix it. Anybody have any ideas? Jim
Old 06-14-2011, 10:37 AM   #9
Run to Rund
Liked 54 Times in 27 Posts
You should be able to take it apart easily; maybe it just needs grease on the gears or bushings.
http://www.superwinch.com/content/Home.index/4377.0.1.1
