Old 05-16-2011, 04:41 PM   #1
racer913
Default first gear ratio change
434 small block 3300 lb car 411 gears 30inch tall tire 5200 stall. changing from 189 first gear in PG to 180 straight cut gear set any ideas of what et will change?
racer913 is offline   Reply With Quote
Old 05-16-2011, 11:01 PM   #2
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Default Re: first gear ratio change
I believe I'd run more gear, say a 513 or so. What's it turning at the MPH lights?
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 05-17-2011, 01:57 AM   #3
greg fulk
greg fulk's Avatar
Liked 5 Times in 3 Posts
It should slow the car....but not much
Old 05-17-2011, 02:44 PM   #4
racer913
traps at 6000 rpm @ 127 mph its a bracket car
Old 05-17-2011, 06:06 PM   #5
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
Not a automatic guy,but I say same to few hundreds quicker,only thing I see that could help would be straight cut planetary may use a little less power than helical gear.
Strength will be biggest gain.IMO
Mike Taylor 3601
