Old 04-22-2011, 04:36 PM   #1
Larry Curtis
Larry Curtis's Avatar
Liked 9 Times in 2 Posts
Default M/T 3056ST tire pressure?
What tire pressure do you run for a stick car with a 29.5 x 9.0 x 15 M/T tire?
Thank you,
Larry
Larry Curtis is offline   Reply With Quote
Old 04-22-2011, 05:20 PM   #2
Stick Racing
Default Re: M/T 3056ST tire pressure?
I run around 11 lbs in my car.
Anything in the 10 lb range still worked but it beat the sidewalls up quickly which greatly cut down on the number of runs I could get out of a set.
12 lbs worked on a good track but any marginal track made the rear of the car skate.
__________________________________
Andy Stone 1102 A/S 1112 SS/C
Stick Racing is offline   Reply With Quote
Old 04-22-2011, 05:30 PM   #3
Bob Gullett
Bob Gullett's Avatar
Liked 507 Times in 116 Posts
I use the Hoosier stick tire and run 11 pounds. When I ran the M/T I used 11.5 to 12 pounds.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 04-22-2011, 06:35 PM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
M/T's always seem to like 10-14 lbs everysize we've had from 8.5X26 to 14X32
we've had em on 12.80 to 8.80's cars only thing constant was all sticks.
Mike Taylor3601
Old 04-23-2011, 10:46 AM   #5
Dave Casey
Liked 797 Times in 165 Posts
rear weight and rim width play a big roll in pressure, allthought 10 -14 is probably the range regardless. My camaro is a 3000 lb car and the only time I run more than 10.5 is with fresh tires on a record/class run or trying to make my fastest run. I have used that tire since 1988 or before. Wish it was a bit taller for my A car, but they can't seem to make a taller one that is as good. hope that helps
Dave Casey 1330 STK
