Old 04-13-2011, 07:17 PM   #1
Bob Lasko
Bob Lasko's Avatar
Liked 186 Times in 55 Posts
Default Trailer Window Ideas
Has any one tried to install a window in a car trailer??? were did you get the window and how hard???
Bob Lasko
Lasko@optonline.net
Old 04-13-2011, 09:34 PM   #2
magnumv8
Default Re: Trailer Window Ideas
trailer windows aren't too difficult to install.....if you have a trailer with an inside wall the first thing you need to determine is the wall thickness from the outside to the inside....when you order your windows you order an inside flanged clamp ring to hold the window in place....if the walls are hollow you would need to put some foam around the opening between the walls so that when the ring is tightened down it holds the window in place without crushing the walls, depending on whether there are seals on the window we will sometimes need to silicone around them to be sure they won't leak.....other windows are available for different applications.....
try www.redneck-trailer.com for some ideas.....
D L Rambo....
magnumv8 is offline   Reply With Quote
Old 04-14-2011, 07:43 PM   #3
Philip Saran
Liked 14 Times in 11 Posts
If your still looking for RV windows to purchase try googling
RV wrecking yards or even check craigslist and see what
you find in your state or nearby.
Out here in SOCAL we have Walts RV in Rialto, CA and
they always have a supply of RV window assemblies out
of MH & TT.
Most places will package and ship to you.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
