03-28-2011, 08:01 PM | #1 |
Chevy parts 4 sale
BRAND NEW 4 SALE 16 Volt Alternators,ultra minis and std,50-100 AMP $150-$275
BRAND NEW, not rebuilt, mini starter, 3 h.p.,168 tooth - $185.We are having a special if you buy two starters they will be $165 each! These are awesome starters for the price! If you pick up starter at track I will discount the starter $5! We also now have a new starter for the biggest of big block Chevrolet's it features a true 3 HP motor,a custom made billet mounting plate, and a severe duty sprag drive assembly. This starter is compatible with 139 Tooth flexplates only (ie J&W,CSR,Meziere). This starter has been tested on engines exceeding 800 CI with awesome results. If you have a Big Cubic Inch Engine and 16 volts then this is the starter for you.Email for price IF YOU DON'T SEE WHAT YOU NEED HERE, I MIGHT BE ABLE TO GET IT. PLEASE, JUST LET ME KNOW WHAT YOU NEED. THANKS SUMMIT PROTORQUE SBC 1.9 HP STARTER USED $110 8-JE NEW LOW TENSION 4.030X3/16 OIL RINGS ONLY- $25 Manley standard length super duty sbc valves, 8-2.055, 8-1.60 ground and ready to install. - $110 GM 1.60 STAINLESS pro flow ex valves NEW - $65 HELWIG HELPER SPRINGS LP2510 $70 Manley #22441 1.550 valve springs,brand new - $110 MELLING M55HV billet gears oil pump NEW - $40 Moroso oil pump pick up #24360 New - $39 Several powerglide cores, make offer Factory front drum brakes 68 camaro $60 NEW Comp Stamped Steel 1.5 Ratio 3/8 Stud part#1212-16 - $40 1.76 Hardened powerglide input shaft TURBO splines USED - $55 RJS 5 point Belts outdated - $25 1 USED SET 12 BOLT GM POSI CLUTCHS $40 Manley raised guide plates #42151-8 $12 ARP#134-7101 3/8 screw in studs $20 USED 12 BOLT 4.56 GEARS $75 sbc chevy casting number 462624-These heads are complete,not modified and need rebuild.$125 stock intake #8927184 SBC EDELBROCK TORKER 2,LIKE NEW $70 OLD STYLE TORKER SBC MANIFOLD USED $50 TRANS DAPT CHROME TURBO 400 PAN $25 STOCK HOOD FOR A 69 CAMARO $110 NOTE: PICTURES AVAILABLE ON PARTS Prices do not include shipping. PLEASE contact Steve at et7333@netzero.net WE NOW ACCEPT PAYPAL
http://stevecoxracing.com |
