Old 03-27-2011, 03:49 PM   #1
George Mirza
Default The "Answer" brake pressure switch
Looking for some info on this setup sold by Folk Race Cars.
What's included in the kit?
Where does it install?
How do you adjust it?
Thanks,
George
George Mirza is offline   Reply With Quote
Old 03-27-2011, 04:47 PM   #2
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default Re: The "Answer" brake pressure switch
George,
The kit includes just the switch, and of course the schematics/instructions.
It installs in the rear brake circuit, preferably close to the master cylinder.
Two wire hook-up, 1 to the two-step and 1 to either 12 positive or negative, depending on your ignition system. It's recommended that a N/C switch be wired in the power circuit to prevent activation in high gear at the finish line.
No adjustment really - pumping the brakes feeds power to the two step, let go of the brakes, hang on!
I'm changing from a single- to a double circuit master cylinder, so this was a good time to plumb in a switch.
Good Luck!
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 03-27-2011, 05:02 PM   #3
Lee Valentine
Liked 319 Times in 68 Posts
George, there is a company in ct. that makes the switch you need. Will get the info monday and post it. Lee.
Lee Valentine 1661 STK
Old 03-27-2011, 07:51 PM   #4
George Mirza
Thanks guys.
Lew,
It goes in the rear brake circuit? Interesting.
Thanks Lee.
George
Old 03-27-2011, 08:01 PM   #5
Lew Silverman
George,
That's where I've seen it installed. It may not matter, except if you're using a chip on your burn-outs.
Lew
Lew Silverman #2070
Old 03-27-2011, 08:33 PM   #6
Todd Boyer
Liked 6 Times in 5 Posts
George, I've heard of using a Volkswagen brake light switch, plumbed into the rear brake circuit for two-step activation. When it sees pressure it is activated (starting line), when there is no pressure (burnout) it's not activated.
Old 03-27-2011, 08:36 PM   #7
Todd Boyer
Originally Posted by Lew Silverman View Post
George,
Good Luck!
Lew
What is a N/C switch Lew ?
Old 03-27-2011, 08:42 PM   #8
Todd Boyer
Perhaps the Folk piece has provision for a high-gear cutout. Also says it's adjustable, what's the adjustment ?
Old 03-27-2011, 09:09 PM   #9
art leong
Willwood 260-1179
59.95
Art Leong 2095 SS
Old 03-27-2011, 09:14 PM   #10
Lew Silverman
Todd,
It's a Normally/Closed switch - you don't want the pressure switch activating in high gear. The wiring schematic shows it better!
There maybe an adjustment on it, although I haven't found it. I guess it would depend on what pressure you wanted the two-step to kick in.
Lew
Lew Silverman #2070
