Old 03-24-2011, 10:04 PM   #1
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default Solid Motor Mounts - Good or Bad?
Has anyone had any bad experiences with solid motor mounts? I had heard that they could deform the cylinder block. Would the poly mounts with a torque brace be more efficient? Should a solid tranny mount be used with the solid side mounts?
Thanks!
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 03-24-2011, 10:39 PM   #2
cad
cad's Avatar
Liked 91 Times in 51 Posts
Default Re: Solid Motor Mounts - Good or Bad?
A couple folks that I know personally have cracked their automatic transmission housings using a solid transmission mount.
Most use solid engine/frame mounts that I know of.
Clark
Old 03-25-2011, 01:25 AM   #3
danny waters sr
danny waters sr's Avatar
Thumbs up Re: Solid Motor Mounts - Good or Bad?
Ran them on my wagon Lew and never had a problem....
Old 03-25-2011, 01:43 AM   #4
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
Solid fronts mounts
Solid mid mounts
Stock transmission mount on fabbed cross-member
55 Chevy is offline   Reply With Quote
Old 03-25-2011, 06:57 AM   #5
Liked 1,835 Times in 417 Posts
Solid motor mounts, a torque restraint, and a polyurethane transmission mount, is the ideal setup, if you're not allowed motorplates. And even with motor plates, front and mid, I use a polyurethane transmission mount, never a solid.
Old 03-25-2011, 09:16 AM   #6
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Used solid mounts and a rubber trans mount for the better part of the 17 years and over 4000 passes I made with this nearly 2 ton ride, without issue. I would never used a solid trans mount.
Old 03-25-2011, 09:32 AM   #7
Lew Silverman
Thanks, everyone!
I'll pick up the mounts this week.
Lew
Lew Silverman #2070
Old 03-25-2011, 10:06 AM   #8
Bimbo Jones
Just wondering, why do they even make a solid tranny mount? I don't know anyone the uses one and everyone will tell you to never use one unless you enjoy broken cases.
Bimbo Jones is offline   Reply With Quote
Old 03-25-2011, 11:41 AM   #9
Circle track guys use them. And people you can't tell anything will try them, then wonder why they're having problems.
Old 03-25-2011, 01:52 PM   #10
mannymen
Liked 13 Times in 7 Posts
Full Chassis cars with 2x3 frames rails. Both of our cars had solid trans mounts and never busted or cracked anything.
N/A
mannymen is offline   Reply With Quote
