Old 03-24-2011, 05:10 PM   #1
rod
Liked 20 Times in 15 Posts
Default shortening piston pins?
for a particular reason i need to shorten my pins .082". i know pins are very hard.
there are no 'off the shelf' pins this size. and i believe this could be done cheaper than buy custom new ones.
any idea how this could be done easily?
thanks rod in AZ
rod is offline   Reply With Quote
Old 03-24-2011, 07:31 PM   #2
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
Default Re: shortening piston pins?
A carbide tool bit in a lathe will cut them.....
OR....
possibly if they fit......the tipping wheel on a valve facer could be used to shorten them. Would be a tedious little operation but I think I've done it.....
Rich Biebel
S/C 1479
Stock 147R
Old 03-24-2011, 07:47 PM   #3
Rick Leininger Jr.
Go only about .010" at a time, and keep the same deburr or chamfer that was on the pin to begin with.
Rick Leininger Jr. is offline   Reply With Quote
Old 03-24-2011, 07:59 PM   #4
dwydendorf
dwydendorf's Avatar
Liked 19 Times in 7 Posts
The best way would be to grind them on a surface grinder in a precision V-block.
ss/gt 93 t-bird
dwydendorf is offline   Reply With Quote
Old 03-24-2011, 08:29 PM   #5
BillK
Liked 30 Times in 17 Posts
Rod,
Whichever way you decide to shorten them, keep in mind that depending on the type of lock that your piston uses, you may have to be very careful to match the chamfer on the end of the pin. Spiral locks require a straight end with virtually no chamfer but a lot of the newer pistons use a round wire lock that depends on the chamfer to force the wire into its groove as the pin tries to move from side to side.
Of course if the pins are press fit into the rod, then none of this matters
Bill Koustenis
BillK is offline   Reply With Quote
Old 03-24-2011, 10:49 PM   #6
Ed Wright
Ed Wright's Avatar
OR....
I've done it with a valve machine. Is slow.
Ed Wright 4156 SS/JA
Old 03-24-2011, 11:23 PM   #7
Adger Smith
Liked 880 Times in 311 Posts
Keep'em cool
Adger Smith (Former SS)
Old 03-27-2011, 05:50 PM   #8
Curmudgeon
Go to any Tool and Die Shop,its an everyday operation like sharpening punches . Best way is block and stack on wet grinder. Best to also give them the length you need instead of just telling them to take 40 off each end. Make sure to have each end ground by half instead of all off one end. Could also ask to have END Rockwelled before and after grinding. Carbide facing will work, but MUST be FLOODED with coolant to prevent softening end where lock rubs. Good luck,hope I was helpful.
Curmudgeon is offline   Reply With Quote
