Liked 4 Times in 2 Posts
we are finishing our 70 Duster! the car was originaly a Kelsey Hayes disc. brake car, we bought Strange front brakes, but there not right for our spindle, and they say they dont have one for that spindle, has anyone used this spindle with aftermarket brakes? Strange,Wildwood, Aerospace. or do i need to change the spindle.
Liked 883 Times in 237 Posts
From my experiance ,you must use the drum brake spindle with Strange and Wilwood.
I dont know if anyone else makes one for the disc spindle.
Liked 419 Times in 85 Posts
Jim,
Depending on the brakes you bought you will either need to use a 10" b body spindle or a 9" a body spindle. The only one that will make the brakes for your configuration will be lamb. |
Jim, what Paul wrote ... on my Barracuda I used 9" drum brake spindles from an A body. Should not be too hard to find .. NAPA still has upper and lower ball joints for them ..
Chuck Beach 3340 STK |
thanks I forgot to mention they have to be drum brake spindles
FWIW, I have the Strange set-up on my car and use the original '73 disc brake spindle. I do know for sure that they are different from the earlier disc brake spindles.
Liked 2 Times in 2 Posts
Wilwood has a kit for the 10" drum spindles.That's what I put on the front of my '71 Demon.
Nautilus Racing |
Thanks for the info.. i found out yes! i do need to put a 9" drum spindle on the car. seams to be the standard one to use...did not know these Kelsey Hayes set up was so different.
Liked 14 Times in 11 Posts
Jim,
If you decide to look for parts, take a look at these web sites. www.fourabodiesonly.com www.moparts.com www.barracudaowernsgroup.com
Phil Saran Parker, Colorado |
Liked 11 Times in 6 Posts
