hey guys whats the best product to clean and maintain a .050 wall trailer, I read on here sometime back a post giving discriptions of the correct products to use and not to use some stuff, may even damage the finish. I have had problems in the past by steaking the polished stuff in the process of trying to clean the exterior and also the extruded alum floors seem to discolor real easy what should be used on them.
just bought a used ATC 32' and it needs a good overall cleanup just dont want mess up more than i fix. thanks in advance for your help wayne hutton |
believe it or not ,nothing gets your whites whiter than 'sunlight' powdered laundry soap. We use it as a car wash soap at the body shop and it does a wonderful job on white paint jobs on fleet trucks which are used in the fields. it does not damage the finish as long as proper washing techniques are used.
Dion Hildebrandt 6009 STK H/SA |
Liked 29 Times in 5 Posts
Jax Wax citrus cleaner. It's the best thing I've ever seen for making a trailer look like new.
SS/AM 2917 |
Liked 886 Times in 238 Posts
Don't use any products using butyl esters such as Spray9 or Greased Lightning . They will streak and discolor the panels.
Strong laundry detergent and elbow grease work best. Dions' correct ,It really works well for body work,strips wax and silicone right off! Dave Riberio had a product he was selling , RV5000 ? I think. That worked really well.
Tom Goldman 1500 SG , 1506 STK Last edited by Tom Goldman; 03-04-2011 at 05:35 PM. |
Liked 100 Times in 45 Posts
Simple Green and about 5 illegal aliens should do the trick.:>):>)
Former NHRA #1945 Former IHRA #1945 T/SA |
#6 | |
Liked 60 Times in 12 Posts
2894 STK |
Liked 3 Times in 2 Posts
Stay away from "Black Streak Removers". They do a heckuva job of taking away black streaks, but they leave "White Streaks" if you're not careful.
Scotchbrite works well on the aluminum floor...all you need is a case of that, a sanding block, and a free weekend. After that initial scrub, there are aluminum waxes that make it easier to restore the shine - make sure you wipe up any water or fluid that might hit the floor and it'll last for a while.
Joe Hertline 1318 SS/FA |
Liked 335 Times in 182 Posts
Ditto on Simple Green do it in the shade and start at the top and work your way down---Get it at Wal mart for about $8 a gallon--its cheap and effective & it works well
Liked 56 Times in 27 Posts
Wayne..... You have a PM.
Dave Ribeiro 1033 STK Last edited by Dave Ribeiro; 05-17-2011 at 10:47 PM. |
Use RV455 to remove tough black streaks and grime. I was sceptical until i used it and It removed black streaks from a trailer that was sitting and not washed for 6 years by just spraying on and wiping off. It strips off the black streaks as well as any wax, so you must wax it right after cleaning.
