Old 02-28-2011, 12:02 AM   #1
Michael Kilduff
Default ? About Wheel Spacers
What is the maximum acceptable (for safety) thickness and material for drive wheel spacers in your opinion or experience?
My application is a street/strip 68 camaro, has 8 inch weld wheels, 12 bolt rear with studs. Engine is roughly 400 hp sbc, glide, 4.10 gears. I have a slight tire rub in the innermost part of the factory wheelhouse, only rubs when going over bumps.
Any advice and info is appreciated.
IHRA STK 932 O/SA
Michael Kilduff is offline   Reply With Quote
Old 02-28-2011, 06:00 AM   #2
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Re: ? About Wheel Spacers
I run a 3/4 in spacer on a 15x12 Weld Alumastar with no problem. make sure you get the billet spacer not the cheap junk spacer. Ed
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 03-01-2011, 09:01 PM   #3
67champ
Liked 4 Times in 2 Posts
The issue I see, is a lot of times the billet is thicker than the racer wants, and five times more expensive...
dt
67champ is offline   Reply With Quote
Old 03-01-2011, 10:10 PM   #4
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Billet is the only way to go. The second most important issue is to make sure that the shoulder style lug nut is used. The thicker the spacer the more torsional flex that will be induced into the wheel studs.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 03-02-2011, 11:02 AM   #5
tj310
We sometimes run 5/16 cast spacers. If you want to run 3/4 spacers you better have 5/8 studs. Make sure if the tire does rub it hits a flat surface, not a sharp edge....Thanx Trevor.
