Old 02-26-2011, 04:38 PM   #1
Geddes
Default Trailer jack recommendations.............
I will purchase an electric trailer jack soon. 24 foot enclosed.......probably weighs the same as everybody's. Scooter,cabinets, tool box and 3000 pound car inside.
What brand ?
Price range?
Quality?
Warranty?
Any brand to stay away from?
Where to buy it?
Thanks all.
Geddes is offline   Reply With Quote
Old 02-26-2011, 05:18 PM   #2
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default Re: Trailer jack recommendations.............
You can spend a lot, or a little...... All depends on how long you want them to last...
I started out with a cheap 3500 lb unit off e-bay ( it is new, and I payed about 130.00). I will see how long it lasts and make my next purchase, decision based on this info.......
Old 02-26-2011, 06:19 PM   #3
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Trailer jack recommendations.............
I have all the stuff in my trailer as you (probably more). I finally bought an electric jack after going through several of the manual type. I bought one from a mom and pop trailer company out West on Ebay. I paid about $150 for one that I saw for up to $280 for the same exact one in other places. It is the black 3500# one with two built in lights on it. It plugs in to your 7 pin trailer hitch or you can wire it to your onboard trailer battery that powers your winch. Had it for over 6 months and no problems. Sorry I don't know the brand. Do your homework though, you can pay a lot or a little for the exact same unit! Jim
Old 02-26-2011, 08:37 PM   #4
Philip Saran
Liked 14 Times in 11 Posts
I am adding an electric jack to my open trailer (has a five foot tall box)
and if the car is loaded I have trouble cranking with the hand crank
(bad back) the jack costs $210 and is wired into the 7 pin plug and
has a light. I don't know the name yet other than that the shop owner
said he did not use Atwood jacks anymore. I will know the name when
I pick up the trailer next Monday or Tuesday.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 02-27-2011, 07:06 AM   #5
rallye bob
rallye bob's Avatar
Jim;
Sounds like the same one I got.......
One thing that I took into consideration when purchasing a jack is some have a head (motor) so big you can't lower the tail gate on the truck. The style jack I got the tail gate just clears....
Old 02-27-2011, 09:22 AM   #6
Greg Barsamian
Liked 427 Times in 97 Posts
Have had good luck with Atwood Tongue Jacks!
It's strong, attractive, has a conveniently mounted light, easy to install,
has an optional hand crank in the event of a battery failure (if for some reason you forget the light on & kill the battery)
Wired it to a 12-volt battery on the trailer that our winch is also wired to, so we can connect & disconnect without plugging into the truck, however when the trailer is in use and plugged in, we use the12 volt source on the 7 pin plug to charge the battery while towing! (always considered this as having a "spare" charged group 24 battery available in case of an emergency)
Take a look around the pit area at trailers to see what manufacturers are installing on trailers?
ATC uses Atwood?
Old 02-27-2011, 12:07 PM   #7
Ed Wright
Ed Wright's Avatar
I have been thinking about an electric jack for my 24' ATC. I was considering an Atwood. What's wrong with them?
Ed Wright 4156 SS/JA
