Old 02-25-2011, 04:41 PM   #1
FLEMING
Liked 55 Times in 26 Posts
Default Better location for weight
Is it better to have ballast straight above the rear end housing as high as you can get it, OR... As far back in the truck as possible? I have heard both...
FLEMING is offline   Reply With Quote
Old 02-25-2011, 08:47 PM   #2
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Better location for weight
That depends on what you want the weight to do for your car.
1. work like a lever around the rear end to lift the frontend for weight transfer
2. be static weight over the rearend to load the shocks or suspension
3. do you want it to help with any law of physics you can apply?
I wouldn't be too concerned with where it was as long as it complimented the setup of the car.
Why don't you fix several places for it and move it around to see what the car likes?
Too big a wheelstand, hang it in the front motor plate or front frame horns
Too much tire hit, hang it by the transmission crossmember
ECT.
Adger Smith (Former SS)
Old 02-26-2011, 09:43 AM   #3
68Mustang
Liked 2 Times in 2 Posts
where would you put it if you were trying to get the car to wheelstand higher
68Mustang is offline   Reply With Quote
Old 02-26-2011, 09:49 AM   #4
Jeff Lee
Jeff Lee's Avatar
as high and as far back as the rules allow.
Jeff Lee 7494 D/S '70 AMX
Old 02-26-2011, 11:10 AM   #5
Hemiparts
Hemiparts's Avatar
Pops (chris3racing) copied an old S&M/Motown Missle design for my Duster that uses a steel bar that's welded to the roll bar down bars in the trunk that puts the weight just behing the rear axle. It has 2 huge bolts welded to it to secure weight right over the rear springs we may also add more bolts toward the center if we need to move weight to the center of the car.
Chris
Hemiparts is offline   Reply With Quote
Old 02-26-2011, 11:55 AM   #6
Ed Wright
Ed Wright's Avatar
Why is that desireable? Mine runs quicker, as long as it dead hooks, with the tired only 4" off the ground. If it's spinning I don't try to keep it down, I let it rotate to hook it. I don't know why some let them get so high on purpose. To high costs mine from a couple-to-5 hundredths. Your results may vary. :-)
And Chris, it's legal to bolt weight to the roll cage?
Ed Wright 4156 SS/JA
