Old 02-18-2011, 09:59 PM   #1
MYLINRACING
MYLINRACING's Avatar
Default 86 trans am brake help
I've been having what i call i soft pedal in my car for the last 3 years, well since I've bulit my car. I used a Ed quay master cylinder and he re worked the pedal, i also run a biondo line lock, I have aerospace brake in the front and drum in the back. Debating weither or not to put disc on the back. I have 3\16 lines in the front and 1\4 in the back. The car won't hold above 2500 rpms and to get it any higher you feel like you are out of the seat. Need some advice on where to start looking to see if i can get the pedal any better.
I've been told I need put 1\4 line up front and also I need to change the rear to disc.
thanks
Andy Mylin
MYLINRACING is offline   Reply With Quote
Old 02-19-2011, 02:59 PM   #2
Karl Owens
Default Re: 86 trans am brake help
I would look into the rear brakes. Make sure they are adjusted properly. You need to make sure there isnt a lip on the rear drums to prevent proper adjustment.
Karl Owens is offline   Reply With Quote
Old 02-19-2011, 03:04 PM   #3
Joe Schweigert
Joe Schweigert's Avatar
Liked 19 Times in 8 Posts
I had that problem in one of my cars turned out to be a problem in the master cylinder I lived with it for a year changed it the the problem went away it was a Chrysler type. Hope this helps
Joe Schweigert 751 SS
Joe Schweigert is offline   Reply With Quote
