does anyone have any experience plotting a timing retard curve for the launch? how much do you take out on the initial hit and for how long? too much power with too small a tire and a stick. thanks-Dan
Not sure how much you have to start with but I usually remove 15 degrees and put it back just before the 60 ft clocks. I have no experience with a stick and this feature but I would have loved this box back in Modified Elim days. Maybe one of the stick guys will chime in with a little better advice. TT
Liked 15 Times in 2 Posts
It's a powerful tool. Not a curve - straight line ramp. So if you have a car with 40 degrees timing and remove 10 degrees for 1 second your result is:
30* at launch 31* .1 after launch 32* .2 after launch 33* .3 and so on till 1 second out you are back to the 40. Regarding how much, I suggest starting with 6 degrees for for you 60' time. Then you correlate results with your data logger shaft & g-meter to tune from there. Give me a call if you need more info. Greg Kelley 609-265-2110 |
I've run the programmabIe ignition for years. I'd talk to Terry or one of the guys at MSD to tell you where to start! You can have them make a program you can down load to your computer or lap top. Pull out to much timing and the engine looses to much power!
