Old 01-25-2011, 03:23 PM   #1
Dave Jung
Dave Jung's Avatar
Liked 5 Times in 5 Posts
Default WTB bowtie block
I'm looking for a bowtie block to build a 305 out of. I believe the #10051182 is what I am after. Thank you
Dave
6535 stk
81 Malibu K/SA
Dave Jung is offline   Reply With Quote
Old 01-25-2011, 04:34 PM   #2
Greg Turk
Greg Turk's Avatar
Liked 19 Times in 4 Posts
Default Re: WTB bowtie block
Dave try Patterson Racing Engines in Augusta Kansas, I believe Alan bought a few of these....this was last year, so I'm not sure if he still has any left.
I just got the machine work done on my own Bowtie, now to finish assembly, I hope it was worth the extra expense.
Good luck in your search these are getting harder to find, Dart now makes NHRA legal blocks however, I'm not sure about a small bore small block.
Turkman
TURKMAN
4002 Stock, 4002 Super Stock
Greg Turk is offline   Reply With Quote
Old 01-25-2011, 04:56 PM   #3
raceman14
I have a couple original in the box GM 1184LW Bowtie blocks ( unmachined ). I purchased 20 of them and built LW Late Model oval track engines out of them, I think the actual weight is about 40-50# less than a standard Bowtie block and this weight reduction was in then casting not machining. I paid $4500 for them and will sell for that as they are no longer available.
I also have a good selection of Uniboring Cup style blocks ( SB-2 & 18* Some Compacted Graphite ), cranks, rods, pistons, cams, heads etc. 23*, 18* and SB-2.
I ship small parts out , a couple time a week and big stuff once a week.
e mail ; mancinelli@att.net
Sorry Dave, bore might be rough 3.900
raceman14 is offline   Reply With Quote
Old 01-25-2011, 06:50 PM   #4
Dave Jung
Dave Jung's Avatar
thanks for the responses guys.
Greg, what is the number of the block you have? And what is the rough bore size?
Dave
6535 stk
81 Malibu K/SA
Old 01-25-2011, 07:27 PM   #5
Greg Turk
Greg Turk's Avatar
Dave,
I've got a 10051182....
its rough bored to 3.650
2 bolt mains with 1pc rear main seal
The max bore can be 4.000
I believe the 10051181, is the other bowtie its 3.875 rough bore,max bore 4.030, 2 bolt 1pc rear, I'm not sure on the "81" but mine is 10051182 and its about 180+ lbs, Im guessing on the weight.
TURKMAN
Old 01-25-2011, 07:35 PM   #6
Dave Jung
Dave Jung's Avatar
thanks Greg, I emailed Patterson engines in Kansas.
6535 stk
81 Malibu K/SA
Old 01-25-2011, 08:13 PM   #7
jeff klei
Patterson will not sell the block unless you have him build you a engine with that block. I tried to buy it also and this is what they told me. Use the dart block and save the hassle.
jeff klei is offline   Reply With Quote
Old 01-25-2011, 08:42 PM   #8
Brett Brown
Liked 5 Times in 2 Posts
Dave
Dave, I just purchased on of these blocks from RacePartsOutlet in Iowa. They told me that they had a few left. The phone number is 515-289-5288.
Brett Brown 7257 STK, SS, COMP
Brett Brown is offline   Reply With Quote
Old 01-25-2011, 09:36 PM   #9
Tom Moock
Liked 10 Times in 6 Posts
Greg, the number # 10051181 is the part number for small rough bore block,the casting number on block is # 10051182. The larger bore part # is 10051183 casting # is 10051184. Some of the 10051182 blocks mite not clean up when bored 3.796 then you need to sell it to 265 or 283 racer. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 01-26-2011, 02:39 AM   #10
Dave Jung
Dave Jung's Avatar
Thanks Tom and Brett, I will check out racepartsoutlet and see what they say.
Am I correct in thinking that I can not use a 4 bolt block as a 305? The only aftermarket blocks on the accepted list is 4 bolt mains, so I assume I cannot use the Dart or World blocks.
6535 stk
81 Malibu K/SA
Copyright ©2000 - 2024, vBulletin Solutions Inc.
Copyright © Class Racer.com. All Rights Reserved. Designated trademarks and brands are the property of their respective owners.
