Old 01-19-2011, 01:42 PM   #1
Rick Angles
Default Odd or Even fire V-6
Ok, I will bring it over here, since I got it started in another thread. My Starfire is a '77, original 305/auto. I had a '75 parts car with a 231 odd-fire V-6. Am I wasting my time with the odd fire? Or look for a 77 even fire and not worry about changing the nose on the car to make it look like a 75?
I thought I would start out with the v-6 first, to have a little fun and see how things go before looking into putting the 305 back in. With the V-6, I would fall in the V/SA class and should be fun for a beginner.
Thoughts?
Rick
Rick Angles is offline   Reply With Quote
Old 01-19-2011, 04:17 PM   #2
Owen S Quirion
Default Re: Odd or Even fire V-6
Thoughts?
Rick, I would swap an even fire crank and cam into the block that you have. I don't have a rulebook in front of me but I think it is legal. If it is, I would get the crank out of one of the later EFI cars that has the factory crank trigger ignition as well. I run an even fire Buick V6 in my car and the balance job works good. I have never had any problems with the crankshaft and I buzz it pretty good.
BF/S 1985 Grand Am 3.0 V6
Owen S Quirion is offline   Reply With Quote
Old 01-19-2011, 08:11 PM   #3
Bench Racer
Liked 99 Times in 21 Posts
Rick I played with an odd fire 231buick 25+ years ago. One of the issues you will run into with the odd fire is the rocker pedastals. They are cast aluminum and crack with a strong stare. Back then they were no longer available from the dealer and if one broke while tightening it down you had to scour junk yards to find a rocker shaft that had a good one. They could easily be made in a machine shop and with no performance advantage over the originals I bet they still would not pass tech. If memory serves me the even fire heads have the rocker pedastals cast into the head. Don Jackson
Bench Racer is offline   Reply With Quote
