Old 01-05-2011, 09:07 PM   #1
TinSoldier 3215
Liked 6 Times in 5 Posts
Default rear gear ratio?
I have a 67 camaro that weighs 3160 with a 400 and the cam is good to 7200. and the car haves a 456 in it now. I was think about a 513 or 538 with tire size 29/50 by 10/50 wide. do you all think it will pull to the 1/4? thanks.
TinSoldier 3215 is offline   Reply With Quote
Old 01-05-2011, 09:19 PM   #2
cad
cad's Avatar
Liked 91 Times in 51 Posts
Default Re: rear gear ratio?
I am putting in a 12 bolt with 4.88s. With 29" slicks, I expect 7000 rpm in the 1/4.
It was in my friend Gregg Pickens' 68 Camaro. With 28x9 slicks, he was at 7200 rpm with his 468 running ~10.80s.
Clark
Old 01-10-2011, 11:08 PM   #3
Geerhead55
Liked 5 Times in 5 Posts
Smile Re: rear gear ratio?
I've got a '68 Nova with a 355/Glide combo. I run 4:88s and with a 10.5 x 29.5 Phoenix tire, I go through the lights at 7200, if that helps.
Danny Durham
Old 01-11-2011, 07:03 AM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
yes but why do you feel you need so much gear?
This '69 Camaro that weighs 3160 with driver having a 400 under the hood topped with a 4150 carb, backed by a glide, 10" converter, 4.56 gear and running on 30 x 10.5 tires and launched off the footbrake sees 7500 in the lights and has been as quick as 9.77 @ 138+ with a 1.27 60 foot
