Old 05-28-2007, 09:18 PM   #1
SST159
Liked 20 Times in 16 Posts
Default Oil pressure problems
Anyone out there ever experience oil pressure dropping to about 10 lbs just after the car passes the 330 ft?
I am out of ideas.
Once the pressure drops, I lift and it will recover right away and I can finish the run with 60 lbs pressure.
Oil pressure is 40 lbs hot at idle no problem
After I saw this I pulled the motor, changed the pump and pickup, went back to the track made a pass and the same thing happened.
I added a qt oil, same thing, added another qt. same thing.
7 qt pan and I usually run 6 qts. ( one in the filter)
Changed the guage, same thing happens.
SBC with moroso eliminator pan 8 1/4" sump. using a Melling pump and pickup.
Any ideas out there?
Drew
S/ST 159
Drew Wonderly
SST 159
SST159 is offline   Reply With Quote
Old 05-29-2007, 03:48 PM   #2
David 7215
Default
It has to be due to either the pick up becoming uncovered under acceleration or the pick up being to close/far away from the bottom of the pan. Put a straight edge across the bottom of the pick up and measure up to the engine pan rails. Your pick up should be around 3/8" from the bottom of the pan. To close or to high, you will have oil pressure problems.
Also, if you run a high volume pump, you may be pumping all the oil up to the valve covers unless you are running restrictors in the cam galley. Restrictors make the mains and rods priority and also get the oil back to the pan quicker. However, you can only run restrictors with roller or flat tappit cams.
Good luck
David 7215 is offline   Reply With Quote
Old 05-29-2007, 05:37 PM   #3
SST159
Default
Dave,
Thanks for the response.
I did check the pickup clearance and it is within the correct range however I learned today that the Melling pickup I am using may not be far enough back in the pan as needed. I am using restrictors and I am using a Melling race pump that is the anitcavitating +10% volume.
My next step is to try a Moroso pump and pickup package that they match to the exact pan I use. The Moroso pickup is a bit different from the Melling.
Drew
S/ST 159
Drew Wonderly
SST 159
