Old 12-21-2010, 05:31 PM   #1
richie 2
Liked 205 Times in 93 Posts
Default Sbc steel head gaskets
im going to use some GM #3830711 (.022" X 4" bore) steel shim head gaskets on a 350ci. corvette resto.... they have come with a black coating (looks like gloss paint) so do they still need sealer as in permatex red spray type? any experiences will help thankyou.
Old 12-21-2010, 06:59 PM   #2
Tom Turner
Default Re: Sbc steel head gaskets
The "red spray stuff" you refer to is Hi Tack and was the sealer of choice for most of us that used steel shims many years ago. Some guys had their own secret sauce (Hylomar, GM brown glup, Super 300 and other conk) but Hi Tack works pretty good.
Dont breathe the stuff cuz it will make you more goofy than Art Leong. TT
Tom Turner is offline   Reply With Quote
Old 12-21-2010, 07:41 PM   #3
G Anderson
Liked 4 Times in 3 Posts
I've used those black coated GM head gaskets several times and do not use a sealer I think that coating serves as a sealer!
G Anderson is offline   Reply With Quote
Old 12-21-2010, 08:03 PM   #4
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Copper Coat spray always worked well for me......I've used those gaskets and they work fine but over a period of time and miles they can fail. I have seen them develop water leaks into an end cylinder right next to the dowel pin.....
Rich Biebel
S/C 1479
Stock 147R
Old 01-12-2011, 08:49 AM   #5
richie 2
here's what i've found....GM # 3830711 steel shim gaskets ordered/recieved have come with a light gray gummy coating on them. .027" thick. there's no "DG" stamp on them like the old days. ("DG" stands for detroit gasket, who was bought out recently by ROL gaskets) the small tab overhanging w/the small ID hole is still present though. im not going to spay tack, the factory coating will be sufficient i'm sure. i will pay close attention to tourque settings/pattern during installation w/ribbs up...thankyou all for you input.
Old 01-18-2011, 12:43 AM   #6
Jack McCarthy
Liked 511 Times in 122 Posts
you may wanna get a composition gasket... the steel shims will rust out in a street car especially one which doesnt run daily...
just a thought !
jack
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 01-18-2011, 08:59 AM   #7
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
just a thought !
jack
???? In how many years?!? Not an issue.
Old 01-18-2011, 09:16 AM   #8
richie 2
we're going to run an antifreeze mixture in the engine so that should help prevent corrosion?
