Liked 2 Times in 2 Posts
Looking for some help with a new T-stop.
I am using a K&R Pro cube with a # 1 air stop and an air shifter triggered on time. Air bottle regulator is showing 90 lbs pressure and excellent volume. Using Timer # 1 for stop and Time # 2 for shifter. I am not using Timer# 3. Stop cycles in pits with motor not running but when I go to make a pass the stop will not activate. Would like to get feedback from anyone using a K&R Pro cube or # 1 air stop. Thanks, Mike |
Guest
Posts: n/a
I am using a K&R Pro cube with a # 1 air stop and an air shifter triggered on time. Air bottle regulator is showing 90 lbs pressure and excellent volume. Using Timer # 1 for stop and Time # 2 for shifter. I am not using Timer# 3. Stop cycles in pits with motor not running but when I go to make a pass the stop will not activate. Would like to get feedback from anyone using a K&R Pro cube or # 1 air stop. Thanks, Mike I would check to make sure there is power to the solinoid when the engine is running, if there is then I would call K&R. Don Higgins Crew Chief PRO Software and Weather Stations www.crewchiefpro.com |
Banned
I used a K&R box and the stop worked in the normaly off position,not the on position,try that
Bryan s/g & s/p 120 s/st & s/c 1219 |
Hey guys thanks for the tips!
Gatsby the t-stop and the air shifter are being run in the OFF position. Appreciate the confirmation! I think I have found the problem. The solenoid is not getting full power under normal running conditions as Don stated. Appreciate all the help! Mike |
