Liked 950 Times in 189 Posts
A friend came across a GM small block all aluminum block with steel sleeves.It has a casting # 0f 366299. Can anyone tell us how old this block is,or what it was used in. it is a 4 inch bore. thanks lyn
Liked 16 Times in 11 Posts
1982 366299 350 - - 4 Chevrolet, aluminium
Bob Pagano A/SA |
Liked 329 Times in 177 Posts
1982 --------- 350 ci. 4 in. bore "early" bowtie aluminum engine block
Lyn---that block also has splayed Nodular 4 bolt caps and is for a WET sump oil system
What was that engine in? Was it installed from the factory? I never heard of an aluminum factory small block.
Guys it is a BOWTIE block---I dunno whether GM ever assembly line installed any Bowtie blocks but I'll bet that they were all aftermarket stuff AND NEVER came in a production vehicle!!! No point running out to your local salvage yard hoping to find one cuz they were/are probably OVER the counter blocks----Comp
Liked 53 Times in 25 Posts
How much are they worth today?
Dennis P Chapman 1904 STK NHRA National Record Holder Car Owner. |
Liked 19 Times in 7 Posts
How many have to be built before its alowed in SS?
![]() http://www.indypacecars.com/1982.html FED 387...you always reply like you are upset. Lighten up its Christmas bro. ![]()
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A Last edited by CrateCamaro; 12-23-2010 at 01:57 AM. |
Sorry I upset ya Crate but a bowtie part usually means it was an aftermarket part not an assembly line installed part so no need to start scouring the junkyards for that part. Ya probably aren't gonna find one UNLESS some guy installed the part and then the car was junked. By the way Merry Xmas to you and your family I'm gonna have a great one cuz I just got my 2 year update on my Prostate Operation I'M CANCER FREE----A side note to everbody go get yours checked out it "could happen to you!!!!" The Doc found mine during a routine physical to renew my NHRA license--FED387
#10 | |
Tony Valerio 1968 Camaro 1700 IHRA H/CM 1701 NHRA SS/?A |
