What electronic devises are needed to be able to run Hot Rod and be competetive. I have an MSD box with the two step, the car has a trans brake and I also run a Biondo Wizard Delay box. I know I need a throttle stop, which one is the best on the market. Any help provided would be appreciated. I would be running Division Four IHRA Hot Rod if all works out. Thanks.
Liked 3,174 Times in 971 Posts
First you need to read this...
http://www.biondoracing.com/tips.shtml#throttle And then call them at Biondo's and they can match the stop to your combo....Sal and really everybody there is easy to talk to and can set you up.
