Old 12-01-2010, 12:41 PM   #1
Bill Grubbs
Liked 564 Times in 66 Posts
Default Edelbrock QuikData - Data Acquisition System (Complete)
32 channel Edelbrock QuikData to including all sensors (with the exception of the Carb Sensor as it died, and oil temp as it read from the gauge). Still has open channels for expandability. This unit worked great when it was pulled from the car. We moved to a RacePak unit.
$1000 for all. The sensors alone are worth more than $1000.
All wiring, and quick disconnects
Fuel pump Pressure
Carb Pressure (will need new sensor)
Engine RPM
Drive Shaft RPM
Oil Temp (reads from the Autometer oil temp guage)
8 EGT’s
2 Oxygen Sensors
Forward Accel (g)
Lateral Accel (side to side g)
Shock Sensor
Oil Pressure
Battery Voltage
Engine Temp
Brake Pedal/Two Step
WBGrubbs at AOL dot COM
716.997.9160
Bill Grubbs is offline   Reply With Quote
