Old 11-28-2010, 03:09 PM   #1
Jeff Lee
Jeff Lee's Avatar
Default Just found this great idea for tie-down
http://www.racingjunk.com/category/1...extenders.html
Just slap them on without crawling under the car with your tie-down hooks.
One of those "why didn't I think of that" ideas!
Jeff Lee 7494 D/S '70 AMX
Old 11-28-2010, 03:55 PM   #2
X-TECH MAN
Banned
Liked 235 Times in 110 Posts
Thumbs up Re: Just found this great idea for tie-down
Cool......I know Im getting to old to crawl under a car and I usually banged my head on something.
Old 11-28-2010, 04:37 PM   #3
Liked 5,124 Times in 1,953 Posts
Default Re: Just found this great idea for tie-down
Good idea,
but something "rubs" me the wrong way about seeing them crossed.
Old 11-28-2010, 08:25 PM   #4
Philip Saran
Liked 14 Times in 11 Posts
Good idea,
Mark, is it that the extensions are metal and you don't like the possiblity of
metal on metal vs crossing of normal tie down straps? Or do you just not
like the idea of using a X system to tie down a vehicle?
Please explain.......
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 11-28-2010, 09:25 PM   #5
No, I cross my straps whenever possible. I've got a piece of padded vinyl velcro'd on them so they don't wear.
I suppose you wouldn't hear this deal rubbing and squeaking inside an enclosed trailer.
I just wouldn't want to see them all galled up after a few trips.
Old 11-28-2010, 11:01 PM   #6
Barry Polley
Guest
Posts: n/a
We have been using those for over a year now Jeff. Fast and they work well. Unhook the front of the car, push the car back and they drop off the diff. Easy to hook up too. Great tool.
Old 11-29-2010, 12:46 AM   #7
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
What happens if your front straps get loose and the car moves.Will they drop off then?I hope not.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 11-29-2010, 01:28 AM   #8
Jeff Lee
Jeff Lee's Avatar
Your still tied down front and rear as before, these are just a link in the middle so you don't have to crawl around the bottom of the car throwing the lasso on the rear end housing. At least that's the way I'm seeing it.
And since I'm getting big-fat slicks under my car, it looks like this will make life easier. Someday...like when I get my car back...
Old 11-29-2010, 02:01 AM   #9
Ed Fernandez
Jeff,read the third sentence in Barry Polly's post.If the front ties come loose what can happan?
Former NHRA #1945
Former IHRA #1945
T/SA
Old 11-29-2010, 01:20 PM   #10
Jeff Lee
Jeff Lee's Avatar
I'm failing to see what the difference would be if you had 4 standard ratcheting straps on the car and the front straps came loose or were magically severed. You would still have the same problem, right?
