Old 11-20-2010, 08:50 PM   #1
rod
Liked 20 Times in 15 Posts
Default MSD dist/SUN machine
i just picked up a nice MSD electronic dist [yes, after 30 years i am moving into the 21 century and away from a point dist.!] this dist. came with no springs/weights on the mech. advance. i would like to put this dist. on my Sun machine and get the curve i want.
my question is; how do you hook the dist up, wire wise, to trigger the arrow.
1. the dist has a + & - wire as does the machine. will this trigger the arrow with a 6 Volt machine battery. if not...........
2. i can hook my MSD 6 to the dist. with the two wire MSD cable [to connect the dist to the box]. jumper a 12Volt battery to the MSD 6, then use the wire [either orange or black, i don't remember which] which goes to the - terminal at the [ not used for this test] coil.
do you think this will work? i don't want to chance hurting either of the MSD parts or my machine.
thoughts
thanks rod in AZ
A bus stops at a bus station, a train stops at a train station.
my desk is a work station!
rod is offline   Reply With Quote
