Liked 169 Times in 53 Posts
I'm putting together a sbc stocker motor for my Nova (71 350/270) . When I put the crank and one rod and piston together in the block, I had a positive deck height. Piston is out about .008. Can I put a thicker head gasket to make up the difference or do the tech people frown on this. Ihad this same thing happen about 20 years ago, got tore down at a race and it passed. I don't know now if the tech people are as benevolent as they were then
Bill Bogues 4696 STK |
Yes, it's covered in the rule book. Good Luck!
Liked 317 Times in 108 Posts
Yes. they total gasket,deck clearance as long as you stay more than that
Mike Taylor 3601 |
My impression is that if the specs call for a negative deck, then the piston had better be below the deck of the block. At this point the gasket is not part of the equation.
The opposite is true if the specs call for a positive deck; the piston had better be above the deck of the block. How much above or below the deck is not the issue as long as the blueprinted engine meets or exceeds the specs; more clearance is allowed, not less clearance. Since your spec is .002" (below deck) then you'll have to machine the big end of the rods to pull the piston down to where it needs to be. Note: this is the same issue as the rocker ratio rule. The end result is not the answer, getting there using the specs provided by NHRA is the requirement.
Jeff Lee 7494 D/S '70 AMX |
#5 | |
What would you say to someone that had a zero deck? Some of the new rods (cracked caps) cannot be resized. I got tossed once because I had a minus .020 deck and the specs called for a plus .004. After that they changed the rule.
Art Leong 2095 SS |
Then I would definitely get confirmation on it.
The "old way" meant if the specs were zero deck then it was zero deck. But as you say, that may not matter. But make sure you have the right rocker ratio when obtaining the spec'ed cam lift measured at the valve! ![]()
#7 | |
But the rule got changed a couple of months later.
Art Leong 2095 SS |
Banned
Liked 235 Times in 110 Posts
Like Art said the rule was changed shortly after Art was tossed for this very same reason. For many years it was as Jeff said. If it was negative deck spec. then it had to be in the hole no matter how thick the head gasket was. One of many changes over the years.
Geez...guess that puts me in old timer category! About when did this change?
When compared to the valve lift / rocker ratio issue, it makes no sense at all.
#10 | |
I'm not sure but didn't the questionable rockers have the ratio stamped into them?
Art Leong 2095 SS |
