Old 11-09-2010, 03:21 PM   #1
Dave1695
Liked 15 Times in 11 Posts
Default what is it?
I have a small block Chevy cast iron manifold part number 3973483. The last digit could also be an 8. (the number is not cast very well). I have searched the NHRA spec sheet but did not find any manifolds ending in 483 or 488. Anybody know what this piece was used on?
Dave1695 is offline   Reply With Quote
Old 11-09-2010, 09:02 PM   #2
Woodro Josey
Liked 3 Times in 1 Post
Default Re: what is it?
Dave, i have run in to this in the past, a lot of the truck manifolds never made it in to the NHRA spec sheets!
Woodro Josey 2002 STK
Woodro Josey is offline   Reply With Quote
Old 11-09-2010, 09:23 PM   #3
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: what is it?
Some of your larger truck intakes, even '73 and later, due to the size exemption of larger trucks,such as 3/4 ton and larger, had no EGR valve provisions. These intakes would never have shown up in any NHRA specs because they never raced any of those vehicles they came on. Trucks that size aren't in the guide, and that resulted in manifold,block and head cores that don't appear in the usual places.I one time saw a non-EGR low profile 454 intake on a big block 71 Chevelle that had a cast date of sometime in '78. Of course, it was an incorrect number, but they were bracket racing it,anyhow.
Old 11-10-2010, 02:15 AM   #4
j h henderson
Liked 6 Times in 2 Posts
According to Alan Colvin's book, #3973469 was a 1971 4bbl Rochester manifold for a 350/270 used in all models.
Jim Henderson
J/S 1029
j h henderson is offline   Reply With Quote
Old 11-10-2010, 12:41 PM   #5
Dave1695
Woodro, I thought it may be a truck manifold but Jim may be correct that the last numbers could be 469. I will have someone with younger eyes check it out. Thanks guys for your help.
Old 11-10-2010, 01:38 PM   #6
Jeff Kempton
Jeff Kempton's Avatar
Liked 66 Times in 30 Posts
Dave, when you're rechecking those casting numbers, check the date numbers that are cast into the top of the manifold as well. Knowing when it was cast often goes a long way towards figuring out what the manifold was originally meant for. I've run into many mystery manifolds and they were almost always from a truck application. Some were also "Made In Canada" pieces that weren't in the guide.
Jeff Kempton is offline   Reply With Quote
