Old 10-25-2010, 11:44 AM   #1
Bruno 3776
Bruno 3776's Avatar
Default Starting Line RPM
A couple questions:
After staging and going to full throttle, does your starting line RPM allow for converter flash or are you at the converter stall? A friend suggested that I should move my RPM to converter stall to help the car move quicker.
While standing on the starting line, I rarely hear cars studder on the two step, more so a solid rev. Is that a result of a specific type of throttle stop being used or something different? Same friend suggested that I could set my RPM above converter stall to limit the engine rev versus using a two step.
My set-up has a two step and electric base plate throttle stop. I feared either of the two suggestions could blow my converter while setting on the transbrake.
Thanks for the info.
Ronnie Dozier
Bruno 3776 is offline   Reply With Quote
Old 10-25-2010, 11:48 AM   #2
Lou SG2340
Default Re: Starting Line RPM
On my car I set the starting line RPM 200 below stall. 6200 stall 6000 starting line
Lou SG2340 is offline   Reply With Quote
