Old 10-13-2010, 07:37 PM   #1
SST 3728
SST 3728's Avatar
Default 1980 Camaro SG SST SP roller or TK
Chrome moly NHRA certified until 5/12
Built by Suncoast with updates later.
Bars up front for front fuel cell.
Fiberglass and removable nose, hood, doors, deck lid, dash and rear bumper.
Weighs 2400 with BBC/glide
Setup for BBC and Glide or TH400, have driveshaft for both (1350 solid u-joints)
Coated 2 ¼” headers
Strange aluminum struts with four piston brakes, and slotted rotors.
Strange 1 1/8” bore master cylinder with coated brake lines.
Griffen aluminum double pass radiator with fan
TCI trans cooler with fan
Dana 60 rear end with the following:
• Double adjustable ladders bars.
• Strange 35 spline pro race axles with 5/8 drive studs.
• Strange spool with 4.88 richmond pro gear, and aluminum girdle cover.
• Koni double adjustable shocks, with ride height adjustment.
• JFZ calipers, steel rotors with aluminum hats.
• Anti-roll
Setup for dual batteries, 4 gallon RJS upright fuel cell in rear.
BG 280 fuel pump with adjustable bypass.
MSD 7AL-2 ignition
ARC overhead switch panel
Simpson parachute
Spring loaded wheelie bars with x-brace
Monocoque lightweight racing wheels
Auto meter ultra-lite series gauges- oil press, water temp, volt, trans temp, trans press.
Proven winner, Division champ car 2009.
Available as complete roller-$14K or Turnkey with 427/481/540 and glide/TH400.
Call ALEX 419-543-3315 cell.
Mansfield, OH
Alex Miller
SST 3728 is offline   Reply With Quote
Old 11-15-2010, 12:47 AM   #2
SST
SST's Avatar
Smile Re: 1980 Camaro SG SST SP roller or TK
you have a pm. thanks
SST is offline   Reply With Quote
