Old 09-25-2010, 02:58 PM   #1
TOM KASCH
Liked 241 Times in 100 Posts
Default Help with a 2006 dodge charger hemi
Our son has a 2006 Dodge charger with bigger heads & cam, headers, etc
It ran great till about 1 month ago, now it shuts off while running.
Any body work on these ?
Got fuel .
Any ideas ?
this is his everyday car.
Old 09-25-2010, 09:07 PM   #2
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: Help with a 2006 dodge charger hemi
have to get the scan tool and put it on continous monitor and see what cuts out ,it also should of logged a code,that should give you a strting point gmonde
Old 09-27-2010, 05:40 PM   #3
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Crank sensors will shut off a Mopar and not always leave a code. ....Also since a lot of work was done around the intake and exhaust ,check the wireing to all the sensors that use a 5v. reference , ie MAP ,CMP CPS ,O2 ,TPS ,ECT. ..... An intermittant short on the 5v circuit will shut down the PCM immediately and will not leave a fault code,as the PCM shuts down to protect its self. ...No data logged either..........I've seen stall outs like this many times ,where the rub on the wireing harness is barely noticable.......make sure the wireing is properly routed in all the stock retainers. .........Tom
