Old 09-21-2010, 11:48 PM   #1
ericsz
Default Delay Box wiring
I have a "Little Wizard" Box. I am a little confused wiring the box and hoping you all can help me..I am trying to figure out how to wire it where I can take it in and out, using a "dummy plug" I am having trouble figuring out what hooks to the 2step and solenoid and what hooks to the button. Do I splice the 2 step and solenoid together and place it on the box terminal marked trans? if so do I only run the 1 wire to the button marked "PB1"? Sorry if this sounds confusing, I have the dummy plug jumpered I just want to make sure the box is wired correctly, I have looked at the diagram and am still confused, I guess I am trying to figure out what gives power to the 2step and solenoid if they arent hooked to the button...Follow me or have I lost you too>
Eric Bowling
ericsz is offline   Reply With Quote
