Liked 22 Times in 22 Posts
Does high cranking compression slow a car down?
don,t have one |
Maybe.. need alot more info to get a better answer.
Liked 313 Times in 106 Posts
depends on why you have high cranking compression? Cam advanced will raise cranking
compression as one example,duration, overlap changes cranking compression,valve lash can change it. compression works both ways like high spring pressure you have one cyl. compressing have another that just fired and is pushing another piston down. just like on valve springs people claim strong springs use power,but when you are opening one valve another is closing it evens it out. proof of that is turn engine with one valve adjusted it will be all you can do to turn engine each one you set engine gets easier to turn when all are set engine turns easy . have you raced much this year? I got to go about 4 times set IHRA F/PS record at Mountain Park Pro Am 4th July weekend went 7.997. May go to UMTR race at Owingsville Ky. this weekend maybe Doorslammers at Ohio Valley. Maybe give more info on what you've got going on might be able to help give me call if need to. Mike Taylor 3601 |
#5 | |
Now I just accept it as one of those things I don't understand. Like how they get those ships in the bottles. LOL
Art Leong 2095 SS |
Thanks guys, here's some details, advanced cam 1 degree, widened valve lash .003, went from 213 to 256 cranking compression, picked up 19 lbs torque, 21 hp with single 4, 51 hp 39 lbs. torque with duels, slowed down a tenth and 3 mph, doesn't make sense to me. The reason we don't go back is we tightened up compression, and that's where everything has to be set. Maybe we just haven't found the sweet spot yet. Will be running at eddyville this weekend in the last modified lbs. per cube, no break-out race this weekend, and we need to have our ducks in a row.
don,t have one |
#7 | |
Liked 20 Times in 12 Posts
Pretty much the same, peak torque at 7900, peak power at 9400. The cam movement was only part of it, tightened clearances for more compression, and different ring package. Actually, it surprised me how much the cylinder pressure went up. Same dyno, same operator.
don,t have one |
Jeff, i agree, i've never had a motor slow down after a gain on the dyno. We always have ran more speed than ET, not uncommon. Ring seal is 1 percent or less. Last year was at 6 percent. Vac went from 17.89 inches to 20.13. Star vac pump. Don't know all the answers, or the car would be running 5.70, 120 mph. But something is not jiving, and we will see this weekend.
All these are 1/8 mile times.
don,t have one |
Are you just looking at increase at peaks? Look at hp&tq average #s over whole pull if you are'nt ,if you gain @ peaks but averaged #'s are less it will be slower to be faster you have raise average #.
Mike Taylor 3601 |
