Old 08-31-2010, 01:30 PM   #1
65Shoebox
65Shoebox's Avatar
Default New Ladder Bars / Afco Dbl Adj Coilovers HELP!
Hello all.
Just got my Chevy II back from the chassis shop for a back-half. Ladder bars and Afco double adjustables.
I have the bars in the middle hole as a starting point. What should I do with the shocks? I assume the top knob adjusts the compression while the bottom knob on the shaft does the rebound. Is this correct?
Should I just count the total number of clicks and start in the middle on both top and bottom?
Car weighs 3025 and ran bottom 10s with 1.4X 60 ft on leafs and Cal Tracs previously.
Thanks for any advice.
65Shoebox is offline   Reply With Quote
