Old 08-30-2010, 10:31 AM   #1
THE LEGEND
Default sst tech questions car under 135mph
Flywheel shield-yes or no?
Window net with roll cage- yes or no?
Alky with belt drive pump fuel cutoff-yes or no?
Car runs less than 135 has stock firewall but removablt transmission tunnel.
Anythingelse I need to know????????????
Thanks
CHip
THE LEGEND is offline   Reply With Quote
Old 08-30-2010, 01:59 PM   #2
Lou SG2340
Default Re: sst tech questions car under 135mph
Yes on flywheel & trans shield
Yes on window net
Don't know on Alky Pump shut off but I would think it would be yes
Lou SG2340 is offline   Reply With Quote
Old 08-30-2010, 02:46 PM   #3
THE LEGEND
Lou,
I called the div 2 office. They gave me a # in California. I talked to a lady there that said.
Yess on the shield
No on the net and cut off.
One more question When is a diaper required?
Thanks
CHip
Old 08-30-2010, 03:32 PM   #4
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
Diaper same deal, break point is 135...under and you're good 'by the rulebook'; speaking of, with a number you can go onto NHRA.com and create a password and then be able to have a PDF or E-Book of the Rulebook. My 2C is put a diaper on if at all practical even if not required.
Just because you're not required to have a cage with a stock firewall doesn't mean any official might interpret a window net requirement a bit different than what the lady in CA indicated...I'd put in a window net and save some future hassles.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 08-30-2010, 05:59 PM   #5
THE LEGEND
I don't have diaper,flywheel shield,or fuel cutoff. I have everything else. will order shield tommorrow. Diaper will have to wait until this winter.
I do have a full cage and window net.
Chip
Old 08-31-2010, 08:21 AM   #6
SCOTT SST2871
Im pretty sure its yes on all three!!
Scott fifield
SCOTT SST2871 is offline   Reply With Quote
Old 08-31-2010, 10:56 AM   #7
jmcarter
jmcarter's Avatar
Scott fifield
Check out all the SST cars running under 135, many do not have diapers...for the time being 135 is the break point for license, chassis cert, diapers, gloves, etc etc....135 is where you have to have a legal SG car (plus the weight of course) to run SST.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 08-31-2010, 11:56 AM   #8
THE LEGEND
Got shield today
Does fuel pump cutoff have to be at Back near cell or inside the car?
Sorry to sound stupid but I don't have a rulebook and can't download until I get a membership #
Chip
Old 08-31-2010, 02:21 PM   #9
GaryGoFast
Talking Re: sst tech questions car under 135mph
Originally Posted by THE LEGEND View Post
Got shield today
Chip
NHRA general regulations state "nom OEM mechanical pump must have a quick action fuel shutoff valve within easy reach of driver and located in the main fuel line between the fuel tank and carbuerator and/or injectors."
If you have a fuel cell, make sure it has a ground strap.
Gary Federico
S/St, S/G 1814
GaryGoFast is offline   Reply With Quote
Old 08-31-2010, 06:08 PM   #10
THE LEGEND
Gary,
Thanks for the info. That is what I thought.
I,m officially a card carrying member of the NHRA again. I've already figured out not to call Cali for anything. LOL
Chip
