Old 08-21-2010, 07:06 PM   #1
Walt Reynolds
Walt Reynolds's Avatar
Default engine paint color
What color paint keeps an engine cooler or does it make any difference at all?
Walt Reynolds is offline   Reply With Quote
Old 08-21-2010, 07:23 PM   #2
Tim H
Tim H's Avatar
Liked 484 Times in 160 Posts
Default Re: engine paint color
I am thinking most will say Black
Old 08-23-2010, 03:49 PM   #3
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
I heard many years ago, 'Da Grump said white........... Great topic for discussion.....
Old 08-23-2010, 04:07 PM   #4
cicero819
cicero819's Avatar
Liked 70 Times in 31 Posts
Doesn't matter what color you use. If you are painting , then emissivity of the paint is the key factor in heat removal by radiation(none nuclear), in other words you could paint it with clear on bare metal and it wouldn't cause any temperature rise. One of the reasons Helicopter Engines aren't painted, plus it saves weight.
Old 08-23-2010, 07:04 PM   #5
Tim H
Tim H's Avatar
25 years ago or so I was at a pretty big name engine builders shop and I mentionned that I noticed most of the engines they were building were painted black. So I said "I see that you guys paint them black to help dissipate heat ?" and he looked at me and replied " no we just use black so oil leaks won't show up so easily !".
Old 08-23-2010, 07:10 PM   #6
SSDiv6
The ideal way would be to blast the metal clean with a matte finish and find a way to protected against corrosion.
The next option would be flat black or any dark matte color. One of the best engine paints in the market is the Caterpillar Flat Black engine paint, it takes a long time to dry, however, if the block is clean and prepped, the paint will outlast anything else in the market. Another good paint is the PJ1 Fast Black motorcycle exhaust paint.
Old 08-24-2010, 12:22 AM   #7
Jeff Lee
Jeff Lee's Avatar
I use a heat dispersing coating applied by MACH Development. Intake, cylinder heads, block, radiator. There's a picture on members rides.
Other than that, I'm told flat black disperses heat best.
Jeff Lee 7494 D/S '70 AMX
