Old 08-21-2010, 10:57 AM   #1
BobUnkefer
BobUnkefer's Avatar
Default Wire gauge for remote charging plugs
I want to relocate the exterior charging plugs on my car and I know that the wire that currently runs from the plugs to the battery is too small, so I ask, what size SHOULD it be?
Looking at approximatly a 4 ft run from the rear bumper to the trunk mounted battery. All the battery cables are welding cable, but does/should the wiring from the remote charging plugs to the battery be the same size?
Trying to get ready for debut @ the Topeka LODRS next weekend, so any & all help is certainly appreciated.
Unk
Bob Unkefer 4409 STK
BobUnkefer is offline   Reply With Quote
Old 08-21-2010, 12:52 PM   #2
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
Default Re: Wire gauge for remote charging plugs
I have always sized the charging wire to fit the highest setting on my battery charger.. That way you get the full advantage of the charger and don't overheat the wire... JMO.... Mack
Mack Reeves
2377 STOCK & SUPER STOCK
Old 08-21-2010, 01:08 PM   #3
magnumv8
Bob.....the gauge of the wire for your charging lugs depends on the input current you plan to supply to the on board battery.....most of the smaller chargers run as small as a 14 ga. wire cause they can only supply maybe a max of a 15 amp charge....but...if your battery is dead enough that you plan to do a "jump start" through these lugs then you better have a cable heavy enough to take the extra current....seeing how you only need 4' of cable you could get away with using a 2 ga. and it would handle most anything you want to do there including a 750 amp "jump"...but if you are weight concious and can jump directly on your on board battery you can go a lot smaller if you want.....
D L Rambo.....
magnumv8 is offline   Reply With Quote
Old 08-21-2010, 02:46 PM   #4
Run to Rund
Liked 54 Times in 27 Posts
"Too heavy" a gauge just gives you a couple pounds of "ballast" so you might as well get heavy enough wire to do anything from those ports. I'd get something like 0 gauge, although the charger won't need that much. If you use them to jump start as noted above, you will be glad you used heavy gauge wire. You can easily get terminals compatible with the gauge of wire and the diameter of the post the terminal bolts to.
Old 08-21-2010, 08:17 PM   #5
BobUnkefer
BobUnkefer's Avatar
PM came that said with electricity you can't be too big.... So I made them out of 2/0 welding cable. 40 amp charger seems to kick in a whole lot better now.
Unk
Old 08-23-2010, 03:46 PM   #6
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
You did good Bob.......... ;-)
