Old 08-18-2010, 10:52 AM   #1
SCOTT SST2871
Default What size fuel line/methanol
Im replumbing my car after 15 years or so because i took one of my lines apart and the fittings were rotted inside from the methanol!! I run a rear mounted fuel cell in a door car with a 4150 carb.right now my lines are 1/2" aluminum and -8 for the feed and return...im changing to all braided hose to get away from as much bare alum as possible..my question is do you run -8hose or -10 hose or -10 for feed/-8 return thanks
scott fifield
SCOTT SST2871 is offline   Reply With Quote
