Old 08-06-2010, 09:41 AM   #1
Chad Rhodes
Default bump steer kits, legal or not
I've heard that bump steer kits are not legal in stock, but I continually see pictures of cars with them. Anyone have a definitive answer?
Chad Rhodes 2113 I/SA
Old 08-06-2010, 10:34 AM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 889 Times in 239 Posts
Default Re: bump steer kits, legal or not
I inquired about this ..........D1 tech told me absolutly no to heims and spacers in Stock, Yes in SS. ......When I called FJ Smith to order one of his F body kits that uses a stock type tie rod end ,he told me there is a lot of confusion as to the legality of the heim and spacer kits, especially in D2................BTW , FJ's kit does the job ,still some bump, but within reason. ......Tom
Old 08-06-2010, 10:46 AM   #3
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Travis from Division 3 told us absolutely no in stock!
Yet, I see several late model "F" body GM stockers with them.
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
Old 08-06-2010, 11:16 AM   #4
FINESPLINE
FINESPLINE's Avatar
Outside of the confusion --division to division--wouldn't a bump steer kit be considered a safety item considering most of the cars wheelstand. Is it because it just another thing to check as far as quality of the heim joints ( as we all know there is good and there is just cheap ). Or is it something they picked so as keep the price of a stocker down and if thats the case they blew it with the camshafts. Me , myself, when it comes to steering, i want the best and I believe the other drivers would feel the same way.
FINESPLINE is offline   Reply With Quote
Old 08-06-2010, 12:43 PM   #5
Jeff Lee
Jeff Lee's Avatar
Or some people should avoid driving race cars that have rules which they are not comfortable with!
Jeff Lee 7494 D/S '70 AMX
Old 08-06-2010, 01:11 PM   #6
Notch1320
Where exactly in the rule book does it state that they are a prohibited item? Have these tech guys pointed this out, or is it just their opinion?
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 08-06-2010, 01:27 PM   #7
jimmyparker
Liked 309 Times in 88 Posts
I installed a bump steer kit on a Stock Eliminator Firebird for a Division IV racer this winter and he assured me that he had Wesley's blessing to do so.
Jimmy Parker
jimmyparker is offline   Reply With Quote
Old 08-06-2010, 02:23 PM   #8
sammy christian
i don't know about "bump steer kits", but it seems a little ridiculous that some tech guy/ wanna be cop, says they are ilegal, when most late-model f-bodies use a pinto rack. the pinto rack, having been approved for stock way back when there was also the '98 LT-1 thing and the narrowed rear. too late to change now. those were all factory pontiac things, just like the stuff ford and mopar are pushing with the cobra jet and drag pack.
sammy christian is offline   Reply With Quote
Old 08-06-2010, 10:07 PM   #9
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
It does not say they are prohibited.
It does say under stock section:
POWER STEERING
May be removed or converted to manual steering. See General
Regulations 3:3.
SUSPENSION, Front
Must retain complete stock front suspension system as produced
by manufacturer for body used. Lift kits/travel limiters prohibited.
Sway bar optional. See General Regulations 3:4.
And under general regulations is says:
3:3 STEERING
Each car’s steering system must be secure and free of defects. All
butt-welded parts must have additional visible reinforcement. Only
conventional automotive steering systems are permitted; flexible
steering shafts prohibited. Rear-wheel steering prohibited, unless
vehicle was originally manufactured with an OEM system. An OEM
system may not be modified, altered, or used in any manner
inconsistent with manufacturer’s specifications.
PLEASE tell me what vehicle came with an OEM or factory production or conventional automotive steering system that had a bump steer kit on it.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 08-07-2010, 12:30 AM   #10
Notch1320
Until the rule book states "no heims" in the steering system, I will argue with any tech guy out there that they are legal.
Does this same thought apply to say caster/camber plates?
What about modified spindles to allow aftermarket brakes to be used?
Shawn Allsup
K/S 718
