Old 07-28-2010, 09:22 PM   #1
1988 olds
Default What shocks would be the best for good 60' times ?
I have a 1988 Olds Cutlass supreme that runs in the low 12's with a sbc 355 , 425 hp and 435 torque. The trans is a 350 w/2500 stall converter. The rear end is stock with traction bars. 60' times with 80 degree track temp and 60 degree air usually run 1.68 -1.70. I use stock shocks and was wondering if different shocks would help the 60' times. Also the front end has 6 cyl. springs with 90-10 shocks. The rear end ratio is 4.10
Any comments as to what I can do to shorten the 60' times?
1988 olds is offline   Reply With Quote
