Need feedback,info and advice regarding best type/brand of steering wheel disconNect device.(removable steering wheel hub).
Will be used on stock gm column with a grant wheel.also must meet sfi 42.1 spec. Thank you! Last edited by SAMATCOTOOLSMAN; 07-27-2010 at 08:50 AM. Reason: SPELLING ERROR |
Liked 9 Times in 2 Posts
I have a Mark Williams disconnect. It is a real nice unit.
Larry |
Liked 858 Times in 234 Posts
Grant #3001 or 3021 are splined for the GM shaft.and 5 bolt pattern .......only difference is one is silver the other is black........I've used these,they bolt directly onto the GM shaft and they are SFI.......Tom
Liked 19 Times in 3 Posts
Het Sam:
Kalak (sp?) had a steering wheel disconnect on his gorgeous Vette at Atco. Maybe someone has a contact no. for him so you'se could talk to him. Say hello to Big Stash for me. Jimmie C. |
